Monoprice Select Mini Painless Extruder Upgrade
Back to overview
Metal MK8 Extruder on the MPSM in 10 minutes with no major disassembly
Al Williams wrote 12/14/2017 at 19:49 point
For some reason the order isn't coming out right... the Advice Before You Start topic should be FIRST. Not sure why it won't edit correctly.
Al Williams wrote 12/14/2017 at 19:55 point
Ok I'm just going to merge that topic with another. Wow, it just seems impossible to get them in the right order :( Ok so look at step #5 first which is just advice, anyway. Then go back to step 1.
