Getting started with Digistump clone
A project log for USB CDC Robosapien V1
Robosapien's actions controlled through a virtual USB port. Speaker switchable between Robosapien & external audio jack
Christoph TackChristoph Tack 02/16/2018 at 21:110 Comments
Where to buy?
Installation
Follow the instructions on:
Programming
The Digistump clone is shipped with a functioning bootloader.
To program the application: first click verify, after that power on the Digistump.
Further reading
Marcus Jenkins wrote an interesting tips & tricks to get you started with the Digistump clone.
Use a USB hub with a power switch for every outgoing USB port.  This avoid having you to plug in and out the USB connector every time the Digistump needs to be programmed.
The schematic can be found here.
