Legacy : Getting started with Digistump clone
A project log for USB CDC Robosapien V1
Robosapien's actions controlled through a virtual USB port. Speaker switchable between Robosapien & external audio jack
christoph-tackChristoph Tack 02/16/2018 at 21:110 Comments
2021 Update : Dump the Digistump
As Adafruit also remarked for its Protrinket 3V: the bitbang USB technique doesn't work as well as in 2014.  The Digistump still works when directly connected to my Thinkpad laptop (on Linux), but not when connected through a USB-hub.  On Windows, it doesn't work at all.
So another platform will be needed with native USB.  I think of the Adafruit Trinket M0 or the Seeeduino XIAO.  The annoying thing is that the Robosapien wedge is mounted using the mounting holes of the Digistump.  We'll have to fix that.
For your reference, the historical Digistump info can be found here below.
Where to buy?
Installation
Follow the instructions on:
Programming
The Digistump clone is shipped with a functioning bootloader.
To program the application: first click verify, after that power on the Digistump.
Further reading
Marcus Jenkins wrote an interesting tips & tricks to get you started with the Digistump clone.
Use a USB hub with a power switch for every outgoing USB port.  As such you can easiliy reprogram the Digistump without having you to replug it to the USB-port every time.
The schematic can be found here.
