identify an element
broken gadget
0 followers
All the kind time and success.
I have a problem, I can not determine the burned element 2N4. I will be grateful to help in identifying the SMD element
Jonathan wrote 12/05/2017 at 22:07 point
(DISCLAIMER: This is not an area I'm very strong in)
According to this random website I found online:
http://www.s-manuals.com/smd/2n
The component in question (given the form factor looks like SOT-323) should be 2N7002W
http://www.s-manuals.com/pdf/datasheet/2/n/2n7002w_fairchild.pdf
The actual 2n4 on that list is not the right entry, by the looks of things.
Vlad wrote 12/07/2017 at 19:46 point
Джонатан,
спасибо за вашу помощь, я постараюсь сделать аналогичную замену. Только когда я измерял размеры, более подходит для SOT-23.
