Weather and Soil Monitoring Device
A device to monitor and display environment
and soil parameters remotely by using the appropriate sensors and IoT.
A device for soil testing and measuring other environmental parameters. The measurements of environment and soil parameters remotely by using the appropriate sensors. It displays the environmental parameters using analog and digital components and also sends the measured data on the internet using IoT.
As a central controller, we used a microcontroller (Arduino ATMEGA2560) that communicates with an Android application, our user interface and the Internet using Ethernet.
The device has many advantages as compared to other weather monitoring systems in terms of its smaller size, huge memory capacities, on-device display, lower cost and greater portability.
The planners and policymakers will be able to make
decisions by considering the output value.
Makerfabs wrote 12/08/2017 at 08:41 point
make it a simple board to avoid the too much wires , would be good idea :)
mk01011998 wrote 12/08/2017 at 12:54 point
Yes I m designing PCB for thiis and thanks for suggestion.
