PCB soldered
A project log for Square wave generator
I found a 74HC294 programmable clock divider in my IC box. After reading the datasheet i liked to build a little box...
ringo2kRingo2k 12/09/2017 at 18:190 Comments
So turning off the soldering station. LCD works, so i am starting to write the firmware for this puppy.
