Wishlist
A project log for Heroineclock II
Giant clock from a PIC18F6585, 135 cheap LEDs, foam core posterboard, hot glue, lots of hot glue
lion-mclionheadlion mclionhead 07/28/2019 at 00:310 Comments
A lot hotter since the thermometer was installed. Lions have debated adding an exterior thermometer, a seconds display, & temperature logging.
The seconds display is the least likely.  It would manely make it easier to wake up as close before the alarm as possible, but it would add a lot more blinking & it would be hard to see.
All enhancements to the thermometer point to a mesh network.  The lion kingdom has a supply of XBees, but they use a lot of power.  Temperature logging for the indoor thermometer would have unlimited power.  Temperature logging outside would require solar power.
