Cleaning and stoning the table
A project log for Rockwell Milling Machine Rebuild
Rebuilding a Rockwell 21-122 Horizontal/Vertical Milling Machine
polyfractalpolyfractal 01/05/2018 at 22:330 Comments
Took a bit of wrestling with the mill, but I removed the table and lead screw.  Wasn't completely necessary, but it made cleaning up the table surface a lot easier.  Degreased everything, evapo-rusted the surface, then lightly stoned out the burs.
Also cleaned and stripped the mill body, and got it masked up for painting. Nearly done!
