The Plan Has Changed..
A project log for IN-12A Nixie Clock Project
Make a clock with IN-12A nixie tubes.
ho-juneho june 12/29/2017 at 10:260 Comments
As planned, nixie tubes are mounted to the top PCB via D'SUB pins. But the pins of nixie tubes are twisted little by little, so I plan to connect the tubes with a standard cable.
