On my Win7 machine, I created a linux VM to host the RISC-V toolchain:
$ mkdir xenial64 $ cd xenial64 $ vagrant init ubuntu/xenial64 $ vagrant up $ vagrant ssh
Then I built the toolchain on the VM:
$ sudo apt-get update $ git clone https://github.com/riscv/riscv-tools.git $ cd riscv-tools $ git submodule update --init --recursive $ sudo apt-get install autoconf automake autotools-dev curl device-tree-compiler libmpc-dev libmpfr-dev libgmp-dev gawk build-essential bison flex texinfo gperf libtool patchutils bc zlib1g-dev pkg-config $ export RISCV=/home/ubuntu/riscv $ export PATH=$PATH:/home/ubuntu/riscv/bin $ ./build.sh
Unfortunately, the build.sh failed. I tried some other linux distros (ubuntu/trusty64, debian/jessie64) without success: the toolchain failed to build for a variety of reasons. Finally, I edited the build.sh file to remove the build of the riscv-openocd tool. (I figured I wouldn't need the on-chip debugger right now.) After that, the build was successful.
