I had some problems getting the Algol CPU tests compiled and run:
- The compiler I built didn't recognize the "-m32" flag specified in the makefile.
- The "riscv_test.h" header file was missing.
- The tests would stall because a memory leak consumed all the RAM after 25% of the tests were run.
I solved these problems by:
- Installing an earlier version of the compiler.
- Grabbing some files from a development branch and adding them into the master branch of my Algol repo.
- Increasing the RAM size of my VM. (This doesn't fix the root cause, but avoids memory exhaustion before the end of the tests.)
With these changes, I decided to record a complete set of the steps to get to this point in case I need to do it again.
First, create the VM and start it up:
mkdir xenial64
cd xenial64
vagrant init ubuntu/xenial64
Edit the Vagrantfile to increase the RAM size:
config.vm.provider "virtualbox" do |vb|
# Customize the amount of memory on the VM:
vb.memory = "4096"
end
vagrant up
vagrant ssh
On the VM, install an earlier version of the RISC-V compiler that was originally used to test this CPU:
sudo apt-get update sudo apt-get install autoconf automake autotools-dev curl libmpc-dev libmpfr-dev libgmp-dev gawk build-essential bison flex texinfo gperf sudo mkdir /opt/riscv sudo chown $USER /opt/riscv git clone https://github.com/riscv/riscv-gnu-toolchain cd riscv-gnu-toolchain git checkout f2a2c87 mkdir build; cd build ../configure --prefix=/opt/riscv make -j$(nproc) make distclean Edit ~/.profile to add: export RISCV="/opt/riscv" PATH="$RISCV/bin:$PATH" source ~/.profile
I modified my Algol repo to add the "env" directory I found in the "develop" branch into the "master" branch:
git clone https://github.com/xesscorp/algol git branch develop origin/develop git checkout develop -- Simulation/tests/riscv_test/env git commit -m "Added env directory needed for compiling tests." git push origin master
Install the Algol CPU repo on the VM:
git clone https://github.com/xesscorp/algol cd ~/algol
Install Python and MyHDL in order to simulate the CPU:
sudo apt-get install python-minimal python-pip sudo pip install myhdl
Finally, compile and run the Algol CPU tests:
./main compile_tests ./main core -a
That's it!
There are 115 tests in the suite: 96 passed and 19 failed. The failures were the timer instruction, the fence_i instruction, and all the atomic memory operation (amo*) instructions.
At this point, I have a (mostly) working simulation of the Algol CPU in MyHDL for me to start experimenting on.
