Just So I Don't Forget (#1)
A project log for Algol RISC-V CPU for CAT iCE40 FPGA Board
Is this a hardware project? A software project? IDK.
dave-vandenboutDave Vandenbout 12/19/2017 at 22:000 Comments
I had some problems getting the Algol CPU tests compiled and run:
  1. The compiler I built didn't recognize the "-m32" flag specified in the makefile.
  2. The "riscv_test.h" header file was missing.
  3. The tests would stall because a memory leak consumed all the RAM after 25% of the tests were run.
I solved these problems by:
  1. Installing an earlier version of the compiler.
  2. Grabbing some files from a development branch and adding them into the master branch of my Algol repo.
  3. Increasing the RAM size of my VM. (This doesn't fix the root cause, but avoids memory exhaustion before the end of the tests.)
With these changes, I decided to record a complete set of the steps to get to this point in case I need to do it again.
First, create the VM and start it up:
mkdir xenial64
cd xenial64
vagrant init ubuntu/xenial64
Edit the Vagrantfile to increase the RAM size:
      config.vm.provider "virtualbox" do |vb|
        # Customize the amount of memory on the VM:
        vb.memory = "4096"
      end
vagrant up
vagrant ssh
On the VM, install an earlier version of the RISC-V compiler that was originally used to test this CPU:
sudo apt-get update
sudo apt-get install autoconf automake autotools-dev curl libmpc-dev libmpfr-dev libgmp-dev gawk build-essential bison flex texinfo gperf
sudo mkdir /opt/riscv
sudo chown $USER /opt/riscv
git clone https://github.com/riscv/riscv-gnu-toolchain
cd riscv-gnu-toolchain
git checkout f2a2c87
mkdir build; cd build
../configure --prefix=/opt/riscv
make -j$(nproc)
make distclean
Edit ~/.profile to add:
    export RISCV="/opt/riscv"
    PATH="$RISCV/bin:$PATH"
source ~/.profile
I modified my Algol repo to add the "env" directory I found in the "develop" branch into the "master" branch:
git clone https://github.com/xesscorp/algol
git branch develop origin/develop
git checkout develop -- Simulation/tests/riscv_test/env
git commit -m "Added env directory needed for compiling tests."
git push origin master
Install the Algol CPU repo on the VM:
cd ~/algol
Install Python and MyHDL in order to simulate the CPU:
sudo apt-get install python-minimal python-pip
sudo pip install myhdl
Finally, compile and run the Algol CPU tests:
./main compile_tests
./main core -a
That's it!
There are 115 tests in the suite: 96 passed and 19 failed. The failures were the timer instruction, the fence_i instruction, and all the atomic memory operation (amo*) instructions.
At this point, I have a (mostly) working simulation of the Algol CPU in MyHDL for me to start experimenting on.
