Status #02
A project log for Build an 8-bit computer
Project inspired by 8-bit breadboard computer of WRKits and Ben Eater Youtube's channels (with updates).
fbio-gilFábio Gil 12/18/2017 at 09:520 Comments
Now the Instruction Register (IR) block is implemented. This register transfer the nibbles separately. The 4-bit LSB nibble is transfered on the BUS, and 4-bit  MSB nibble on the Control Block further up. This is a differential feature in relation to another registers that can transfer an entire byte on the BUS.
