• ASSEMBLE GRIPPER
    dannyvandenheuvel12/15/2017 at 10:25 0 comments
    All 3D parts
    Filament Colorfabb nGEN gray
    Filament Colorfabb FLEX black
    Servo motor Modelcraft VSD-15E
    8 x m3 nuts
    2 x 16mm bolt (DIN 912 m3 x 16 12.9)
    2 x 40mm bolt (DIN 912 m3  x 40 RVS)
    2 x 45mm bolt (DIN 912 m3 x 45 RVS)
    2 x 50mm bolt (DIN 912 m3 x 50 RVS)
    10x 9,5mm screws (DIN 7983 2,2x9,5 RVS)
    Building it togetter,
    Added mini servo
    Place gears, you have to cut the original servo star plastic to fit into the gear.
    Take some tape to hold the nuts on place!
    All parts togetter to bring into the bottom part.
    Parts placed into bottom holder. (check servo wire)
    Add flexible vilt at the grip left and right
    drill holes and screw them onto the grip.
    Grip with flex vilt
    Grip added to body
    Both grips assembled on body.
    Some pics of the result, ready to use.
  • THE SMALL SERVO
    dannyvandenheuvel12/11/2017 at 20:56 0 comments
    The mini servo motor I used for this project, will be printing this week, after testing I will put all files online.
  • Exploding gripper
    dannyvandenheuvel12/11/2017 at 18:27 0 comments
    Baaaaammmm, parts flying around, this is how the compact gripper has been build!
