ESP8266 MAX7219 Dot Matrix Display as MQTT Client
Back to overview
A MAX7219 driven Display, controlled by an ESP8266 SoC and MQTT
Jameshooper wrote 10/13/2018 at 09:50 point
Hi. When I save the mqtt settings, after rebooting it has returned to default settings.
ninharp wrote 05/11/2018 at 12:05 point
You can rebuild the source if you have installed the toolchain for esp, the esp open sdk and the Sming Framework. Paths are set in the Makefile. Or you can go to the github page of the source and download the firmware.tar.gz on the root directory, this archive contains a full flashable binary
harkirat wrote 05/11/2018 at 04:14 point
How i can get the binary
tokaphi wrote 02/21/2018 at 17:04 point
hello, how can I have the binary file to test please.
Thank you
sommo wrote 01/30/2018 at 15:57 point
Hi!
beautiful! i would try it, but can't find any files or binary. could you share those files?
Or point me to how to build?
Thank you.
