TinyPong
A keychain sized gamer based on the attiny85 and a single coin cell battery.
2 player pong with hardware control and sound effects. more info coming...
  • Pong in 80 Lines of code.
    Saul04/19/2023 at 02:05 0 comments
    I said 100, got it done with 80 lines of "Game code".
    Could be cleaner, the whole sketch is about double and the padal placement needs a bit of work.
    1. Adding a ball Spin or acceleration when a hit is made with the padal moving.
    2. a ball Split extra if you match the ball speed and hit on the corner of the padal.
    Pong Arduino Oled Code Below...
  • Touchless Controls?
    Saul04/12/2023 at 23:01 0 comments
    Added an oled screen to my ultrasonic walking stick mock up test circuit for testing/finding limits.
    Immediately realized it would make the perfect PicoPong Circuit.
    • 2 Player pong - Distance sensor output maps to paddle position.
    • alternate xy or other inputs for other games...
    Need to convert/rewrite the game for the full oled library but pong is pretty easy, I think I can do it in less than 100 lines of code... maybe..
  • Is this a bug?
    Saul04/08/2023 at 07:55 1 comment
    Or I really should have done a kickstarter for this.
    310 views and 310 follows? so everyone that looked followed.... ?
View all 3 project logs
