So, now we will show you how to use balanced ternary in VHDL (tested in Xilinx ISE v9.2i on CPLD CoolRunner-II). Similarly to Logisim approach when 2 "binary" wires were used to simulate 1 "ternary" wire we can define new VHDL type to handle ternary and call it "FakeTrit" that will be BIT_VECTOR with 2 wires in it - VHDL package built around this approach may look like this:
PACKAGE ternary IS
SUBTYPE FakeTrit is BIT_VECTOR (1 downto 0);
SUBTYPE FakeTriad is BIT_VECTOR (5 downto 0);
SUBTYPE FakeTriadWithParity is BIT_VECTOR (7 downto 0);
CONSTANT O : FakeTrit := "00";
CONSTANT P : FakeTrit := "01";
CONSTANT N : FakeTrit := "10";
CONSTANT X : FakeTrit := "11";
FUNCTION buf(T: FakeTrit) RETURN FakeTrit;
FUNCTION inv(T: FakeTrit) RETURN FakeTrit;
FUNCTION mux(T_C: FakeTrit; T_N: FakeTrit; T_O: FakeTrit; T_P: FakeTrit) RETURN FakeTrit;
FUNCTION e12(T_C: FakeTrit; T_N: FakeTrit; T_P: FakeTrit) RETURN FakeTrit;
FUNCTION e21(T_C: FakeTrit; T_N: FakeTrit; T_P: FakeTrit) RETURN FakeTrit;
END PACKAGE ternary;
PACKAGE BODY ternary IS
FUNCTION buf(T: FakeTrit) RETURN FakeTrit IS
begin
case T is
when N =>
return N;
when O =>
return O;
when P =>
return P;
when others =>
return X;
end case;
end;
FUNCTION inv(T: FakeTrit) RETURN FakeTrit IS
begin
case T is
when N =>
return P;
when O =>
return O;
when P =>
return N;
when others =>
return X;
end case;
end;
FUNCTION mux(T_C: FakeTrit; T_N: FakeTrit; T_O: FakeTrit; T_P: FakeTrit) RETURN FakeTrit IS
begin
case T_C is
when N =>
return T_N;
when O =>
return T_O;
when P =>
return T_P;
when others =>
return X;
end case;
end;
FUNCTION e12(T_C: FakeTrit; T_N: FakeTrit; T_P: FakeTrit) RETURN FakeTrit IS
begin
case T_C is
when N =>
return T_N;
when O =>
return T_P;
when P =>
return T_P;
when others =>
return X;
end case;
end;
FUNCTION e21(T_C: FakeTrit; T_N: FakeTrit; T_P: FakeTrit) RETURN FakeTrit IS
begin
case T_C is
when N =>
return T_N;
when O =>
return T_N;
when P =>
return T_P;
when others =>
return X;
end case;
end;
END ternary;
4th state X (11) might be used as an exception to detect error during simulation.
Now we can implement ternary half-adder (see example in previous log) in VHDL:
use ternary.all;
entity main is
Port ( a : in FakeTrit;
b : in FakeTrit;
c : out FakeTrit;
s : out FakeTrit
end main;
architecture Behavioral of main is
signal r1,r2,r3,r4,r5,r6 : FakeTrit;
begin
process (a,b)
begin
r1 <= mux(a,P,N,O);
r2 <= mux(a,O,P,N);
r3 <= mux(b,r1,a,r2);
r4 <= e12(a,N,O);
r5 <= e21(a,O,P);
r6 <= mux(b,r4,O,r5);
s <= r3;
c <= r6;
end process;
end Behavioral;
It takes 4 macrocells (out of 256) of Xilinx CPLD CoolRunner-II XC2C256/144 (or 2%).
All results of activity around this could be found on GitLab:
SHAOS
