So now we have everything to build a ternary computer in binary CPLD (or FPGA)::
https://cdn.hackaday.io/files/285791222723936/ternary.vhd
Last pieces were just added:
- procedure dmux:
PROCEDURE dmux(signal T_S: IN FakeTrit;
signal T_C: IN FakeTrit;
signal T_N: OUT FakeTrit;
signal T_O: OUT FakeTrit;
signal T_P: OUT FakeTrit) IS
begin
case T_S is
when N =>
T_N <= T_C;
T_O <= O;
T_P <= O;
when O =>
T_N <= O;
T_O <= T_C;
T_P <= O;
when P =>
T_N <= O;
T_O <= O;
T_P <= T_C;
when others =>
T_N <= X;
T_O <= X;
T_P <= X;
end case;
end;
- component ternary_mem:
-- Entity ternary_mem
USE ternary.ALL;
ENTITY ternary_mem IS
PORT (
T_S : IN FakeTrit;
T_N : IN FakeTrit;
T_P : IN FakeTrit;
T_Q : OUT FakeTrit
END ternary_mem;
ARCHITECTURE Behavioral OF ternary_mem IS
BEGIN
PROCESS (T_S)
BEGIN
IF (T_S(0) = '1') THEN
T_Q <= T_P;
ELSIF (T_S(1) = '1') THEN
T_Q <= T_N;
END IF;
END PROCESS;
END Behavioral;
- component ternary_clock:
-- Entity ternary_clock
USE ternary.ALL;
ENTITY ternary_clock IS
PORT (
B_C : IN BIT;
T_C : OUT FakeTrit
END ternary_clock;
ARCHITECTURE Behavioral OF ternary_clock IS
signal flag : bit;
BEGIN
PROCESS (B_C)
BEGIN
IF (B_C'event AND B_C = '1') THEN
IF (flag = '0') THEN
flag <= '1';
ELSE
flag <= '0';
END IF;
END IF;
IF (B_C = '1' AND flag = '0') THEN
T_C(0) <= '1';
ELSE
T_C(0) <= '0';
END IF;
IF (B_C = '1' AND flag = '1') THEN
T_C(1) <= '1';
ELSE
T_C(1) <= '0';
END IF;
END PROCESS;
END Behavioral;
Last one turns binary clock into ternary sequence NOPONOPONOPO...
Also I renamed some variable names and added additional components for mux and dmux ( just in case if somebody doesn't like them as functions ; )
SHAOS
