Now we will simulate ternary full adder:
Using ternary.vhd described in previous log, we can do this architecture in VHDL:
use ternary.all; entity main is Port ( a : in FakeTrit; b : in FakeTrit; c : in FakeTrit; s : out FakeTrit; c2 : out FakeTrit ); end main; architecture Behavioral of main is signal r1,r2,r3,r4,r5,r6,r7,r8,r9,r10,r11,r12,r13,r14 : FakeTrit; signal a1,b1,c1,s1,cc1 : FakeTrit; begin process (a,b,c) FUNCTION io_invert(T: FakeTrit) RETURN FakeTrit IS begin case T is when N => return P; when O => return X; when P => return N; when others => return O; end case; end; begin a1 <= io_invert(a); b1 <= io_invert(b); c1 <= io_invert(c); r1 <= mux(a1,O,P,N); r2 <= mux(a1,P,N,O); r3 <= mux(b1,r1,r2,a1); r4 <= mux(b1,r2,a1,r1); r5 <= mux(b1,a1,r1,r2); r6 <= mux(c1,r3,r4,r5); r7 <= e21(a1,N,O); r8 <= e12(a1,N,O); r9 <= e21(a1,O,P); r10 <= e12(a1,O,P); r11 <= mux(b1,r7,r8,O); r12 <= mux(b1,r8,O,r9); r13 <= mux(b1,O,r9,r10); r14 <= mux(c1,r11,r12,r13); s1 <= r6; cc1 <= r14; s <= io_invert(s1); c2 <= io_invert(cc1); end process; end Behavioral;
io_invert is function to do bitwise inversion for inputs and outputs, because we are using 3-state switches (0 is active state) and 3-wire Red-Green LEDs (0 is active state) - schematics below repeated 3 time on the board with CoolRunner-II:
This is 1+1+1 = 3
This is (-1)+(-1)+(-1) = -3
Pin assignments:
NET "a<0>" LOC = "P140" | IOSTANDARD = LVTTL ; NET "a<1>" LOC = "P142" | IOSTANDARD = LVTTL ; NET "b<0>" LOC = "P138" | IOSTANDARD = LVTTL ; NET "b<1>" LOC = "P139" | IOSTANDARD = LVTTL ; NET "c<0>" LOC = "P136" | IOSTANDARD = LVTTL ; NET "c<1>" LOC = "P137" | IOSTANDARD = LVTTL ; NET "s<0>" LOC = "P87" | IOSTANDARD = LVTTL ; NET "s<1>" LOC = "P88" | IOSTANDARD = LVTTL ; NET "c2<0>" LOC = "P85" | IOSTANDARD = LVTTL ; NET "c2<1>" LOC = "P86" | IOSTANDARD = LVTTL ;
This ternary full adder ate 8 macrocells (4% of XC2C256):
And this is logic equations generated by Xilinx ISE software:
Next step - MEM...
