Raspberry SPY NoIR
Although the "Stock" RPi NoIR camera lens gives super sharp pictures...It lacks that SPY Cam touch.
There are many fixed lens solutions out there....but still what is one too do when you need that slight edge........
....Zooooom on in .... I stumbled across a 1/3" 5mm-100mm compact CCTV Zoom lens.
The key to project is the 3Dprinted mount I constructed (STL file link <
The Rig :-
Below was hastily strapped together as I wanted to catch a firework display off the top of my House.
Anything goes when you leave things too late , and precious time burns....
View all 2 project logs
kumkum1kiran wrote 02/23/2015 at 10:35 point
Home surveillance is becoming very popular as people feel the need to keep an eye on their surroundings when they are away at work or some other place.One such solution is using Raspberry Pi which can record videos on motion detection. The recorded videos can be streamed online. Just go through.. Itz an amazing Project... You should try this
https://www.mepits.com/project/254/Latest-Project-Articles/Raspberry-Pi-as-low-cost-HD-surveillance-camera
Adam Fabio wrote 08/26/2014 at 05:39 point
Very cool setup! I've done this sort of thing with a webcam and an old lens - looks like I may have to print out a mount and try a few of my old 35mm lenses!
chiprobot wrote 08/26/2014 at 14:44 point
Tnx...Still have to tidy the rest of the build.... (ie box it in with a RPi case).
Yes 35mm lens adaptors should be easy to construct , not sure about the focal length though.... Its worth a try.
