Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
DIY Octopus
Nokia 5110 display as "Game & Watch" lcd
Build a nintendo game & watch octopus clone using a nokia lcd and an ATMEL AVR microcontroller
Thomas BaumThomas Baum
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
1 comments
9 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 1
View Gallery
1.1k
1
9
4
Team (1)
  • Thomas BaumThomas Baum
Join this project's team
hardware
ongoing project
avr nokia 5110 lcd attiny diy Nintendo octopus
This project was created on 12/15/2017 and last updated 4 years ago.
Description
With the easy to remove reflective foil, the nokia 5110/3210 lcd is perfectly suited as display replacement for projects like this.
In this case i want to build my own Octupus game. My original? Lost. Since I was eight.
Project Logs
Collapse
  • The background
    Thomas Baum • 12/15/2017 at 16:12 • 0 comments
    The following PDF contains the backround-image. Crop marks are integrated. Remove the reflective foil and insert it into metal LCD display frame.
    http://tiny.systems/software/octupus/OctupusBackground.pdf
View project log
Log In/Sign up to comment
Sign up with Github
OR
davedarko wrote 12/15/2017 at 10:45 • point
I've seen this as a Gamebuino port, but it really adds to have those graphics on the display :) Cool
1.33 to 30.33 MHz FET DIP Meter has 8 x 2 LCD frequency display. Unit measures a small 5.5 x 2.5 x 1.1 inches. www.HecKits.com
Project Owner Contributor
FET DIP METER
Darrel HeckendorfDarrel Heckendorf
LC Meter measures inductance & capacitance and displays value on a 8x2 LCD display. Measures 5.5x2.5x1.1 inches. www.HecKits.com
LC Meter
PIC Library for 2.4 TFT LCD Display Shield Touch Panel ILI9341
ILI9341 PIC Library
iloilo
Simple, Pygame-driven and easy to duplicate weather display
Big Weather Bug
Rob HafernikRob Hafernik
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Octopus", please tell us the reason.
Send message
Remove Member
