No serial, so add an LED
A project log for Holiday 8-bit ^2 LED Ornament
An 8x8 LED matrix animated ornament powered by an ATtiny85
toddTodd 12/19/2017 at 08:180 Comments
No debugger, no serial (well, when using nearly all the pins, and most of the Program Storage), you have to go by your gut. Or, add an LED and set it to light at certain checkpoints/conditions.
I also added a decoupling cap.
