Below is an image illustrating the different phases involved in this project:
My initial experiments involve seeing whether carrot seeds will germinate in sealed PET bottles containing soil and enough water. Why carrots? There are several reasons: they are the right shape to be able to extract from a bottle once they have grown without having to cut the bottle. They have quite a high energy density (about 40 calories per 100g). Fibres from carrots and other similar root vegetables can also be used as the basis for making composite materials, so could potentially be used as a construction material on Mars as well as a food source.
I’ve chosen to use PET bottles because they are readily available, and because the screw-on cap makes it easy to attach a CO2 sensor. Once I’ve spent a bit of time figuring out whether carrots can be grown like this, I want to produce a set of instructions so that anybody can do it, using PET bottles that they have at home.
Everything that the carrot needs to live and grow must be contained within the bottle. An obvious question is where the carbon dioxide that the carrot needs to grow will come from, since the air in the bottle when it is sealed contains only a small amount of CO2. From reading around the subject, I believe that decomposing organic material in the soil will release CO2, which the carrot will make use of. Microorganisms in the soil will in turn consume the oxygen that the carrot produces during photosynthesis.
At what rate does soil produce CO2, and at what rate will the carrot consume it as it is growing? Since the carrot will consume less when it is smaller, there might be an overproduction of CO2 initially. Will this matter? These are some of the questions that I hope to answer during the course of this project. I purchased a CO2 sensor (MH Z14A) and mounted it in an enclosure that will screw onto a bottle in place of the cap to see what happens to the CO2 level in the bottle.
All software source code and hardware designs that are part of this project are covered by the GNU General Public Licence version 3: http://www.gnu.org/licenses/gpl-3.0.en.html. You are free to change and share this work, but in doing so you must make sure that others are free to do the same under the same terms as this license.
I love grow chambers and a single carrot grow pod is truly charming.
Now I'm super new and my actual technology skills are fairly raw however I can tell you are never going to get an actual carrot tuber with straw hat LEDs. Inadequate lighting is thee most common oversight I see on grow chambers. You're going to need something much beefier and its going to chafe against your desire for efficiency I suspect. You're trying to replace the sun and carrots are a full sun plant. Most plants will germinate and do okay under low light conditions for a little while but you won't get a mature plant. This is especially true if you're trying to get an actual carrot which is a carbohydrate (direct by product of photosynthesis) storage organ. Not enough light for photosynthesis = not enough carbohydrates to store.
A very basic overview of light requirements for plants can be found here:
http://www.hort.vt.edu/ghvegetables/documents/GH%20Lighting/Light%20in%20the%20Greenhouse_JBrown.pdf
Something a bit more complex here:
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3949401/
For those who don't have the time to read those links. Although efficiencies can be had by just using specific colours of LEDs that correspond to the peak adsorption spectra of chlorophyl A & B you still have to hit them with enough photons to drive photosynthesis. Straw hats just don't have enough. Also it should be said that all though those other wavelengths of light that aren't the peak absorbance spectra for chlorophyl A & B can still be utilized for either photosynthesis by way of accessory pigments or for information about the surrounding environment (the proportion of red light relative to far red light reaching a plant on of the ways how they sense if they are being shaded by another plant). See:
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4407068/
So by excluding other spectra of light you will still get growth but you can end up with a biochemically different end product. This isn't necessarily a bad thing and could actually be used to produce things like lettuces that are enriched for certain vitamins or nutrients simply by growing them under different lighting regimes. See:
https://www.ncbi.nlm.nih.gov/pubmed/?term=Sequential+light+programs+to+affect+kale+sprout+appearance
LEDGardner has a really solid write up on quantifying light in a way that makes sense for plants. Unfortunately most commonly used units for quantifying light (lumens, lus, footcandles, etc) are biased towards human colour perception (we see a lot green very well and most of us don't see UV at all) and/or don't quantify actual photon density). See:
http://ledgardener.com/lumens-par-ppf-and-ppfd-measuring-cob-grow-light-output/
Additionally LEDGardner has lots of helpful guides on how build yourself punchier growlight:
http://ledgardener.com/diy-guides/
Hopefully my info dump is both helpful and not discouraging. Its an opportunity to build a dope as growlight.
