Hot-wire Foam cutter
A project log for 'Bird of Prey II' Super Long Range VTOL UAV
Flight time and versatility will be vastly extended using a combination of multirotor, blended wing, and hydrogen fuel cell technologies.
kendoken.do 01/19/2018 at 05:310 Comments
NiChrome wire arrived the other day.
I am using 32 gauge Nichrome 60 (10 ohm/ft)
The plan is to use this wire as a hot wire foam cutter wire to cut the wings and possibly rough out the body of the fusilage.
To power the wire, I have a DC motor speed and direction controller which I connected to opposite ends of the wire.
I stashed this motor controller that can deliver up to 24V inside of a variable speed electric nail file body (don't ask) an attached a super cheap voltage monitor with display so i could see what i was cooking with. Silicone coated wires came forth carrying voltage and were terminated with alligator clips to attach to the nichrome wire.
Pictures will follow eventually...
