RH_RF95.hadded registers for FSK/OOKx-chdr - 61.45 kB - 12/23/2017 at 23:06 |
RH_RF95.cppchanged init around a little bit. The changes will break the examples that come with the RadioHead library.Instead of calling init() call init_LoRa(). Then the examples should work again. x-c++src - 17.03 kB - 12/23/2017 at 23:06 |
