octet-stream - 65.39 kB - 10/30/2018 at 05:43 |
boxTool.zipfor upgrading the resumer 3d box firmware and settings.x-zip-compressed - 10.78 kB - 04/18/2018 at 09:34 |
check_example.pngThis is the screen capture while run Printer_check.exePortable Network Graphics (PNG) - 51.81 kB - 04/17/2018 at 11:38 |
Printer_check.zipUse this software tool (for Windows) to check whether your 3d printer can be worked with our resumer3D box. check 2 points: gcode command(marlin is ok) and which the usb driver chip your printer use.x-zip-compressed - 11.45 kB - 04/17/2018 at 03:15 |
