communicating with x10
12/24/2017 at 20:49 • 0 commentsI wrote a simple flask app just to get things up and running. When a url is curled from the command line the web app sends the appropriate even to the microcontroller which sends the command to the x10 devices.
from flask import Flask import serial x10 = serial.Serial('/dev/ttyACM1', 115200) proj = serial.Serial('/dev/ttyUSB0', 9600) app = Flask(__name__) @app.route('/') def hello_world(): return 'Welcome!' @app.route('/living_room_lamp_on') def living_room_lamp_on(): x10.write('A011') return 'Living room lamp on.' @app.route('/living_room_lamp_off') def living_room_lamp_off(): x10.write('A010') return 'Living room lamp off.' @app.route('/bedside_lamp_on') def bedside_lamp_on(): x10.write('A021') return 'Bedside lamp on.' @app.route('/bedside_lamp_off') def bedside_lamp_off(): x10.write('A020') return 'Bedside lamp off.' @app.route('/bedroom_tv_on') def bedroom_tv_on(): x10.write('A031') return 'Bedroom tv on.' @app.route('/bedroom_tv_off') def bedroom_tv_off(): x10.write('A030') return 'Bedroom tv off.' @app.route('/living_room_tv_on') def living_room_tv_on(): proj.write('POWR 1\r') return 'Living room tv on.' @app.route('/living_room_tv_off') def living_room_tv_off(): proj.write('POWR 0\r') return 'Living room tv off.'
