Bulk Print
A project log for K-raft
A Construction set. Made of flat pieces. 3D-printer friendly.
andrey-kalmatskiyAndrey Kalmatskiy 01/03/2018 at 15:470 Comments
Most parts take only 15 layers on my FDM printer. So printing of one set doesn't take long, but I want more parts to be printed in one session. Ideally hundreds of parts at once.
Parts are flat.  What if I stack them layer by layer with a thin gap?
Here is the stl: 1x1-32.stl
A gap of 0.3 mm makes one loose layer.
Here it's printed:
And cut with utility knife:
New parts work good. They are like the previous flat printed parts except for underside which has very rough surface due bridging.
I tried them in practical usage.
It works. If needed, I can make about 500 flat parts in one print.
