New mini Deflection PCB's
A project log for BUILD an ARCADE XY VECTOR MONITOR
I set out to build a working 13"-27" CRT Arcade XY Vector Monitor. UPDATE!!! 5" and 9" monitors too.
fredkonofredkono 09/17/2016 at 23:550 Comments
New tiny deflection pcb's arrived and assembled. These run off from + - 12v and are good for 5-9" crt's. They also can replace the deflection in a vectrex and enable the vectrex to run arcade games with a great picture.
