Deflection PCB's are in.
A project log for BUILD an ARCADE XY VECTOR MONITOR
I set out to build a working 13"-27" CRT Arcade XY Vector Monitor. UPDATE!!! 5" and 9" monitors too.
fredkonofredkono 08/26/2014 at 16:291 Comment
I ordered 10 pcbs from China and they are in . They turned out good and seem to be very high quality. They are 10 cm X 10 cm.  I designed the PCB to take 2 kinds of power resistors and actually found the NI 10 Watt resistors for a good price so I used them.  The circuit is a loose copy of the Amplifone with the WG6100's  spot kill circuit.  I used Tip35C and Tip36C transistors for the outputs and Tip31C and Tip32C's replaced some older transistors.  I am still waiting for some more parts to arrive so that I can start to test these.
Guille wrote 02/08/2019 at 01:31 point
Im trying to run vector graphics on old crt tvs to play oscilloscope music and would be interested in acquiring or buying your custom pcbs, is this possible?
