This is the 9" color TV with the chassis removed.
Yoke Removed. I used the heat gun to loosen up the glue on it.
Yoke disassembly.
#24 wire ready for its new home.
92 Turns each side.
The yoke put back together. I used hot glue to hold the parts like the old glue did.
fredkono
Are there supposed to be images in this log entry? I don't see any.
Hackaday long since dropped them for some reason. You can check out our facebook group. "Vectrex, XY monitors the technical side".
