Yoke Rewind
A project log for BUILD an ARCADE XY VECTOR MONITOR
I set out to build a working 13"-27" CRT Arcade XY Vector Monitor. UPDATE!!! 5" and 9" monitors too.
fredkonofredkono 09/01/2014 at 19:266 Comments
This is the 9" color TV with the chassis removed.
Yoke Removed. I used the heat gun to loosen up the glue on it.
Yoke disassembly.
#24 wire ready for its new home.
92 Turns each side.
The yoke put back together. I used hot glue to hold the parts like the old glue did.
PointyOintment wrote 03/17/2019 at 10:08 point
Are there supposed to be images in this log entry? I don't see any.
fredkono wrote 03/17/2019 at 14:18 point
Hackaday long since dropped them for some reason. You can check out our facebook group. "Vectrex, XY monitors the technical side".
andyhull wrote 09/18/2014 at 21:20 point
andyhull wrote 09/18/2014 at 21:17 point
.. and how did you calculate how many turns to use?
David Preece wrote 09/18/2014 at 21:02 point
*Why* did the yoke need to be rewound?
fredkono wrote 09/18/2014 at 22:48 point
Not enough current can build up to move the beam with the original windings. In other words the yoke used in a TV has too many windings on the vertical side because it is wound to run at a slow frequency.
