New XY monitor kit on the way.
A project log for BUILD an ARCADE XY VECTOR MONITOR
I set out to build a working 13"-27" CRT Arcade XY Vector Monitor. UPDATE!!! 5" and 9" monitors too.
fredkonofredkono 02/17/2017 at 19:492 Comments
UPDATE!!! Long overdue. Some very exciting things are happening. I've complete the XY deflection, High voltage section and crt driver for a plug and play kit that will work for most 5"-9" crt's and ordered the parts for a small run. James Sweet has also finished his vector daughter board. A board that plugs onto a cheap Altera Cyclone FPGA board and so far lets you run Asteroids and Asteroids Deluxe for true hardware goodness. I've added a couple pictures of the prototype deflection and James FPGA board running on a vectrex crt. The screenshot is terrible, but trust me it looks amazing in person.
Steve Baines wrote 04/18/2017 at 09:47 point
A kit you say?  Put me down as very interested!
fredkono wrote 04/18/2017 at 12:55 point
I have a couple kits. More info at https://www.facebook.com/groups/1060033634089063/
