A good explanation of the noise encountered in this circuit. Noise in very low frequencies grows because of 1/f noise rather than the nV/root Hz rating. 1/f noise is the reason you need blocking caps. The nV/root HZ rating of an op amp is actually for a very small bandwidth. It actually compounds as the bandwidth increases. His explanation of RMS noise is a bit easier than TI's.
