My project would not be possible with out the hard work and extreme dedication of these people and those who support them.
Teensy 3.1 and Teensy-LC. Thank you Paul Stoffregen!
pjrc.com
github.com/PaulStoffregen
USB Host Shield Mini. Thank you Oleg Mazurov!
circuitsathome.com
github.com/felis
Also xxxajk (Andrew J. Kroll) wrote spi4teensy3, Thank you!
github.com/xxxajk/spi4teensy3
Paul Stoffregen also has a forum for project help, loaded with great information like this Teensy Quick Reference: Code Examples, Tips and Tricks.
Oleg Mazurov wrote an awesome series of articles that go over the basics of USB report descriptors and HID.
Visualizing HID device reports and report descriptors:
A simple introduction to USB interface and report descriptors.
https://www.circuitsathome.com/mcu/usb/visualizing-hid-device-reports-and-report-descriptors
HID support for USB Host Shield Library 2.0 released:
Interfacing to HID boot protocol devices.
https://www.circuitsathome.com/mcu/hid-support-for-usb-host-shield-library-2-0-released
Arduino USB host Articles:
Arduino USB host – Communicating with HID Devices
https://www.circuitsathome.com/communicating-arduino-with-hid-devices-part-1
Arduino USB host – Pre-prototyping – Part 1
https://www.circuitsathome.com/mcu/programming/arduino-usb-host
Arduino USB host – First programs – Part 2
https://www.circuitsathome.com/mcu/arduino-usb-host-part-2-classes
Arduino USB Host – USB Descriptors – Part 3
https://www.circuitsathome.com/mcu/arduino-usb-host-part-3-descriptors
Arduino USB Host – Peripherals – Part 4
https://www.circuitsathome.com/mcu/arduino-usb-host-part-4-peripherals
Lightweight USB Host Articles:
Lightweight USB Host. Part 1 – Motivation
https://www.circuitsathome.com/mcu/lightweight-usb-hostpart-1
Lightweight USB Host. Part 2 – Hardware
https://www.circuitsathome.com/mcu/lightweight-usb-host-part-2
Lightweight USB Host. Part 3 – accessing MAX3421E
https://www.circuitsathome.com/mcu/lightweight-usb-host-part-3
Lightweight USB Host. Part 4 – The code
https://www.circuitsathome.com/mcu/lightweight-usb-host-part-4-the-code-repository
Lightweight USB Host. Part 5 – control transfers
https://www.circuitsathome.com/mcu/lightweight-usb-host-part-5-control-transfers
Lightweight USB host. Part 6 – introduction to HID
https://www.circuitsathome.com/mcu/lightweight-usb-host-part-6-hid
Other Links:
Circuits@Home.com USB Host Shield References
USB Host Shield Projects: A summary and Links for Hardware
information, Arduino Libraries, and Application-specific information
https://www.circuitsathome.com/arduino_usb_host_shield_projects
USB Shield Blog: Some are older articles not used here, but have
valuable information.
https://www.circuitsathome.com/category/mcu/arduino/usb-shield
Hardware Manual with Pictures of how to hook up the hardware!
- Layout (Pinout descriptions)
- Basic Usage
- Power Options (3v & 5v limitations)
https://www.circuitsathome.com/usb-host-shield-hardware-manual
(Compare with Teensy 3.1 “USB Host Shield Library” below.)
Teensy 3.1 USB Development Board References
Teensy 3.1 – Main Page: New Features, Technical Specifications, and
Pinout Diagrams.
http://www.pjrc.com/teensy/teensy31.html
Teensyduino
Teensyduino is a software add-on for the Arduino IDE software.
http://www.pjrc.com/teensy/teensyduino.html
Also see
https://forum.pjrc.com/threads/28207-Arduino-1-6-2-support
Download the Arduino Software
http://www.arduino.cc/en/Main/Software
Download Teensyduino
http://www.pjrc.com/teensy/td_download.html
Teensy 3.0 now supported by the USB Host library: 3.1 support and
pinouts!
https://www.circuitsathome.com/mcu/teensy-3-0-now-supported-by-the-usb-host-library
USB Host Shield Library with Pictures of how to hook up the hardware!
- Hardware Requirements
- USB Host Capacitance
- USB Host Power Voltage (Power requirements for all devices)
http://www.pjrc.com/teensy/td_libs_USBHostShield.html
(Compare with USB Host Shield “Hardware Manual” above.)
Teensy 3.x Native USB Host Preview Available 3-24-2015
Looks like something else to play with.
https://forum.pjrc.com/threads/28173-Teensy-3-x-NATIVE-USB-HOST-PREVIEW-AVAILABLE
Digital I/O
http://www.pjrc.com/teensy/td_digital.html
USB Serial
http://www.pjrc.com/teensy/td_serial.html
USB Keyboard
http://www.pjrc.com/teensy/td_keyboard.html
USB Mouse
http://www.pjrc.com/teensy/td_mouse.html
SPI Library
http://www.pjrc.com/teensy/td_libs_SPI.html
frankstripod
My goodness! That's quite a bibliography!
Does that mean it's functioning already?
I just wanted all the links for these two boards finally in one
place. Also the articles were hard to find in order. Just the SPI is
working now! :) https://hackaday.io/project/2872-driverless-mouse-and-keyboard-sharing/log/20016-atmel-atmel-atmega328p
