Using two half-sized perma-protos, screwed together with a brass spacer in between, create a soldering platform that allows you to easily solder 0.1 inch pin headers perpendicular to your break out boards every time.
For the base of our platform we will use one half-sized perma-proto. It is separated from the soldering platform by brass spacers.
Add another spacer.
Attach the brass headers using screws on the from the bottom.
2
Step 2
Add the top platform.
For the actual platform we will be use a second half-sized perma-proto... Any size will do, really, but the top and bottom should be the same type.
Attach the top perma-proto.
Use two more screws from the top to attach the top perma-proto. Using brass spacers will allow you to take this apart if you need the perma-proto for another project. Its like having a ready spare!
3
Step 3
Add Rubber Feet.
Ensure that the thickness of the feet is greater than the screw head thickness.
