With most aquariums, you need a filter to remove muck, and also to extract toxins from the water. I used to make filters out of PVC tubing, but i decided to design a filter that would be fully 3D printable, and modular. I may create a separated project for it later, but here's a video explaining it :
Compared to other DiY filters, this one takes longer to physically create, since you have to wait for the printing. However the printer works alone :)
Assembly is fast (a few minutes), and the filter can be altered, expanded, modified, etc...
If you want it larger, simply print more chambers and install them!
See you next!
Audrey Robinel
