Esp Telegram BOT matrix
Esp Telegram BOT that show message on a dot matrix display
This code receive a massage from a Telegram Bot and respond of a specific requests. One of this command can display ( /disp ) a msg on the Matrix display.
When the device is new for the network, the BOT becomes a WiFi station. You can connect to the wifi station and enter the credentials of your network.
The device have a deep sleep mode ( the pink wired in the schematic ) that guarantee a low power consuming during the WiFi station mode.
I added an RFID Tag inside the case with the link to a chat with the BOT.
For every info, visit the GitHub link.
Library for my project
I used different library for my project:
Telegram bot:
Dot Matrix:
I decide to edit the origin library because i wanted a boolean command that can return to me when the all words are displayed.
This command is:
scrollEnd();  // it return 1 when the word is completely displayed
The library that include this and other command is this.
WiFi manager:
At some point in my project, i decide to drug it outside my home, just for a test.
When i was in the the lab, without my pc, i found this new problem:
"How can i change the WiFi that connects my device?"
I searched on the internet and i have found this amazing library for doing the WiFi manager job without my pc!
Standard Tesselated Geometry - 1.29 MB - 12/28/2017 at 10:38
Download
Standard Tesselated Geometry - 55.55 kB - 12/28/2017 at 10:37
Download
  • RFID tag
    Dave12/29/2017 at 12:23 0 comments
    Write in the Tag this link
    https://telegram.me/<bot username>?start
View project log
