Version from 2016
A project log for LED ring
A charlieplexed 20 LED blinker with ATTiny45. Space efficient daisychained LED placing with shared anode/cathode soldering pads.
jens-haukeJens Hauke 01/30/2018 at 09:550 Comments
This is an older version of the LED Ring. PCB-less, hand-wired on a small acrylic sheet. Holes are drilled with 0.8mm and the thing is powered by two LR726 cells.
