Indicator
A project log for Drill press illumination
Restoring illumination to an industrial drill press.
niel-malanNiel Malan 01/02/2018 at 16:590 Comments
Today I soldered up the indicator LED.
I made the holes in the Veroboard for feeding the wires through with the Dremel tool. This is something I can get used to.
I think I'm going to to glue it all into place using hot melt glue.
Here's the bottom side. Smartphone cameras suck at focusing. Also, I suck at cleaning up used fragments of Veroboard.
