Electrocard
Ever since I have my own company I wanted to have a PCB business card. What not add an OLED display to it?
Ever since I have my own company I wanted to have a PCB business card. Of course I wouldn’t be the first, but it would definitely give a nice touch to my company’s identity. And since I wanted to give KiCad a good try anyway, why not go for it?
Of course it’s fun to just make a fake pcb layout, but it would be even better if an assembled version of my business card really had some nice features. Since I managed to get a bare SSD1306 OLED working, there wasn’t any excuse to not accommodate the business card with an OLED display.
I wanted to add a nice easter egg. I already programmed Pong once. But with the 3 push switches and the width 128x32 pixel screen, i reckon Tetris was better suited. Or to be more precise: horizontal Tetris. The added benefit of tetris is that it doesn’t need a high frame rate. And honestly, seeing such a cute little Tetris game on a business card, brings a smile to most people’s faces. :)
Graphics Interchange Format - 1.66 MB - 12/30/2017 at 19:31
Preview
Download
  • 1 × ATTINY85 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × SSD1306 OLED
  • 1 × 2032 COIN CELL
D Kearns wrote 07/03/2018 at 20:57 point
I know adding holes to a PCB raises costs.  Cutouts for the display, switches and the battery (moved to the edge for insertion/ removal) could make for a super-thin build.  Switch to a CR2016 and you get even thinner.  The display could be sandwiched between two clear stickers for durability.  The hardest part I see would be sourcing a mid-board battery holder.  Just more V2 options.  The new ATTiny1607 has micro-power and some more IO at a lower price point (i'm seeing sleep with a cap-sense wake ISR). This build is still very nice.
Michael Teeuw wrote 07/04/2018 at 07:10 point
These are all valid options, but keep in mind that the unpopulated board is my default business card. Real prospects get the populated version. For the unpopulated version is better to have a "solid" version. :)
eekster wrote 01/24/2018 at 19:38 point
Don't know much about electronics, but could you add 2 more buttons or is there not enough pins on the chip? Something like those 99-in-1 brick games from the 90s would be fun! Also does it work on 128x64 OLED?
Michael Teeuw wrote 02/09/2018 at 19:01 point
I used all the available pins. There are some tricks to add more. Or I could switch to the ATTINY84 which has a few more pins. The biggest issue is memory. I wrote a blogpost about this if you are interested: http://michaelteeuw.nl/post/164184894587/electrocard-part-3-writing-the-software
janussanders wrote 01/20/2018 at 18:55 point
Is there any way you can post the Kicad footprint and 3D model for the SSD1306 128x32 Oled display?  I'm inspired by your project and would like to try and create my own.
janussanders wrote 01/23/2018 at 18:46 point
Thank you. Again, I'm inspired by your work!
Vishnu M Aiea wrote 01/13/2018 at 07:32 point
Just beautiful <3
Michael Teeuw wrote 01/22/2018 at 13:56 point
Thanks! :)
Trey Keown wrote 01/11/2018 at 02:40 point
Mind if I ask how much this costs? I'm building an interactive business card at the moment myself, but I'm hesitant to do too much due to the cost.
Michael Teeuw wrote 01/22/2018 at 13:58 point
The PCB itself is about $1 a piece. When you add all the components, it's about $8 total. I mostly used components sourced from AliExpress. It's a hell of al to cheaper than any other marketing campaign, an it's sure as hell effective: people don't throw away this card, and tend to show it to others (coworkers and business contacts).
michael24h wrote 01/10/2018 at 18:44 point
Very Nice ;-)
Thanks! :)
janussanders wrote 01/10/2018 at 18:41 point
Great job!
Thank you! :)
Mike Szczys wrote 01/09/2018 at 16:10 point
Wow, that screen looks really great. Nice job on this project!
Thanks! I appreciate it.
Richard Hogben wrote 01/04/2018 at 23:24 point
Nice business card. A version with a hole for a lanyard would make a nice conference badge too!
Michael Teeuw wrote 01/22/2018 at 13:59 point
Thanks! Nice idea! I'll keep it in mind for v2. :)
