Hackaday.io Hackaday.io
Sign up Log in
FPGA development board
Spartan 6 and Atmel SAM3U general purpose development board. Designed for DIY assembly.
tommirouvaliTommiRouvali
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
6.9k views
1 comments
224 followers
  • Description
  • Details
  • Files 0
  • Components 8
    • View all
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 1
View Gallery
6.9k
1
224
36
Team (1)
  • tommirouvaliTommiRouvali
Join this project's team
FPGA SDR SAM3U development board
Related lists
SMART ARM-based Projects
Atmel®|SMART MCUs combine powerful 32-bit ARM cores with industry-leading low-power technology and intelligent peripherals.
Atmel Parts
Projects using Atmel hardware
This project was created on 03/05/2014 and last updated 3 years ago.
Description
This is general purpose FPGA+ARM development board. My goal is to use it as software defined radio building block. But this board is designed to be general purpose, so it can be used for almost anything. It contains poweful Atmel SAM3U ARM processor with integrated high speed USB with 480Mbit/s transfer speed. FPGA on board is Spartan 6 XC6SLX9. This is one of the biggest FPGA chips available with TQFP package. It contains 16 DSP48A1 slices and also 2 CMT blocks (integrated PLL). Board has 55 general purpose IO pins from FPGA and 7 IO pins from SAM. Board can be assembled at home, but board manufacturer house for board making is recommented. Board also contains MMC card slot, FLASH chip for FPGA configuration data and few oscillators for frequency generation.
Components
  • 1 × XC6SLX9-2TQG144C Spartan 6 FPGA $15.69
  • 1 × ATSAM3U2CA-AU Atmel SAM3U $6.09
  • 1 × ASFLMB-72.000MHZ-LY-T 72Mhz oscillator $2.19
  • 1 × W25Q80BVSSIG Flash memory $0.38
  • 1 × AMS1117 3.3 Regulator 3.3v $0.12
View all 8 components
Build Instructions
Collapse
  • 1
    Step 1
    Board schematic is located at
    https://github.com/OH1TR/oh1tr-fpga-devboard
    I also have some code writen to this and it will be added soon.
View all instructions
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
AVR wrote 03/27/2014 at 02:16 • point
Now this is cool
The development board uses the STM32F04 microcontroller which you can order yourself and solder the components yourself.
Project Owner Contributor
STM32F04 DEVELOPMENT BOARD
mrqMrQ
A small STM8S105K6 development board
STM8S Development Board
sebastian-blockSebastian Block
Simple, tiny USB to UART converter, with a splittable galvanic isolator
Debug Board Splittable Isolator
saimonSaimon
A searchable database with detailed specs of 100's of single board computers and embedded modules.
The Single Board Computer Database
devicegurudeviceguru
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "FPGA development board", please tell us the reason.
Send message
Remove Member
