close-circle
Oxy Cube
Oxy Cube is a small device that measures all the essential things for air pollution, which than sends values to the server using WiFi
close
Oxy Cube is a small device that measures all the essential things for air pollution, which than sends values to the server using WiFi or something other.
This project will help to unite all people so that we can measure air pollution and share it with one another. This platform will be intended for all hardware and software developers.
This project will also be open source and will be published on github. After making my hardware, I will do my best to make a 3D printed box, a mobile application and a web application.
Also, the hardware code will be opened, so many will be able to add a new sensor and share it with the community. This is just the beginning of the project, so support me, you can give some ideas or post some links .
Stay tuned !
  • 1 × esp32
  • 1 × pms7003
  • 1 × HT01
  • 1 × CP2102 Microprocessors, Microcontrollers, DSPs / USB Microcontrollers
  • 1 × USB Connectors and Accessories / Telecom and Datacom (Modular) Connectors
  • PCB Finished !!
    Armin Salčin01/17/2018 at 23:27 2 comments
    PCB is finished !!
    Now i need to check pcb and order it !
  • Start design of schematic and PCB
    Armin Salčin01/16/2018 at 14:30 0 comments
    Currently i started to work on schematic and pcb for project . I choose esp32 as main MCU  , also combined with pms7003 (PM sensor) ,  and other sensors , this will be nice little device !
  • Let's start project
    Armin Salčin01/03/2018 at 14:30 0 comments
    Firstly what i think when i start this project is , it need to be small compact an easy to use. So i started thinking about dimensions i came to dimension like 6cm x 6cm or similar. So we need to put all electronic components and sensors in that area. One big question is what sensors to put on it ?
    As i do research  these parameters are important :
    - Temperature
    - Humidity
    - CO , CO2
    - PM
    - UV index
    - Light intensity
    - VOCs
    Except these parameters we have other like : altitude , compass , noise...
    This device will be  portable one  but also as device to put on your balcony .
View all 3 project logs
