Building a workspace
Making a 75 square foot space in the Artisan's Asylum into a work space.
What goes into taking a bare 75 square foot space and turning it into a productive space to get some work done.
AA website: http://artisansasylum.com/site/
AA floorplan: http://wiki.artisansasylum.com/index.php/Category:Craft_Areas
MY SPACE!!! #59
I also get to use half of those upper three red shelves, but I'm not sure how I'm going to get to them to store things.
Any ideas?
  • 1 × 48" x 24" x 72" metal frame shelf with wooden boards.
  • 1 × 24" x 24" x something like 7 feet wire shelf with wheels
  • 1 × Corner table raised to be a standing desk
  • 1 × 2' x 6' table
  • 1 × 18" x 4' table
  • Lighting and space is still an issue.
    Alan Kilian03/07/2015 at 16:54 0 comments
    I'm finding myself spending a lot of time rearranging things as I move from a soldering project to an oscilloscope project and back.
    The latest change I made is to stack one table on top of the other and mount a 2 Foot long fluorescent light under the top one. This makes for good lighting and I can swap items from the lower table to the upper one fairly quickly.
    I think I'll get my for a while using this method. We'll see.
  • Lighting improvements.
    Alan Kilian01/12/2015 at 15:49 0 comments
    I need to improve the lighting since I'm just using clamp-on 120 VAC floodlights.
    I got a bunch of 12 VAC pendant cable lights like these. Brilliant Lighting cable lights.
    and I need to figure out how to get them wired up.
    They use a GIANT 120 VAC to 12 VAC transformer and some impressive cables in their original form.
    i think I'll rewire them for hard-wired 12 VAC, but I've got to figure out how heavy a wire to use.
    These are 12 VAC 50 Watt bulbs, so P/(I*E) = 50/12 = more than 4 Amps each.
    I'll have to look at cables and see what I can come up with.
  • Unpacking #1
    Alan Kilian09/05/2014 at 11:25 0 comments
    Unpacking stuff.
    Sheesh. It looks like I took a little bit too much stuff from my house.
    It's going to be quite a squeeze to get everything in.
    AND, I packed some boxes (like three) by just dumping random things into a box. That's going to be rough getting the stuff sorted out.
    I need to buy some plastic bins to store the sorted stuff.
    BUT I can see that this is going to work out really well.
  • Move-in day!
    Alan Kilian09/03/2014 at 11:35 0 comments
    Tuesday evening, Maggie and I moved in shelves and tables!
    This metal shelf has been used before, and it's a little wonkey.
    I really don't care for the way these selves bang together, but it's something I have, so I'll use it.
    We did get it together, and it's stable, so it'll be OK.
    I do really like the other chrome wire shelf. I don't know where I got it from, but I like it. Strong, stable, and has wheels!
    I'm going to have to be very disciplined about how I organize stuff since I don;t really have any extra room to keep junk around.
    I'm moving from a suburban basement into an urban 75 square foot space, so only the precious and most useful bits will make it into the permanent lab.
    I'll figure out how to add photos of the space next.
  • Building the shelf unit at home.
    Alan Kilian08/29/2014 at 14:52 0 comments
    We built the shelf unit for use at home last night and I'm impressed.
    The unit can be built with the shelf supports in two positions.
    One has the shelf sitting on top of the support so items can slide on and off easily.
    The other has the shelf sitting in a 2" deep "box" formed by the shelf supports.
    I'm planning on assembling the shelves with the front support even with the top of the shelf so I can slide things onto it and the side and back supports making a 2" deep surround so things don't get pushed off the side or back of the shelf.
    I'll post photos next week.
    One thing I'm not sure I'll like is that the shelves are wire rods instead of solid.
    I think I'll need to add some thin plywood or something on some of the shelves to keep things from dropping through.
    i do like this shelf and I'll be buying another one for use at AA.
  • Shelves.
    Alan Kilian08/28/2014 at 14:13 0 comments
    First thing is to build some shelves.
    I like those angle-iron with the two mushroom-shaped deals that clip into slots in the angle iron.
    However, the ones I've used have pretty sharp edges and are hard to get the lower and upper angle irons to start attached.
    Just yesterday, I found a 60" wide by 24" deep shelf of this type that looks much better.
    They have wire racks instead of wood.
    They have rolled edges which are not sharp and should improve stability.
    They have a clip to hold the lower and upper angle together.
    $135 is not TOO outrageous.
    I got one for home and I think I'll get one for this space.
  • Space number.
    Alan Kilian08/28/2014 at 13:58 0 comments
    I'm in space number 59!
    I'm thrilled to be so close to the social area and other action-packed spaces.
View all 7 project logs
