Ordering parts from McMaster Carr
A project log for BuildLog Laser 2.x build
This week* i will be mostly putting together a buildlog.net 2.x laser
charliexcharliex 03/08/2014 at 17:110 Comments
I choose to do the packs, since it is all useful bits and pieces and no matter how many of those darn pack of nuts, bolts screws, etc i buy from HF etc i never have the right ones.  These quantities are for individual part quantities, and not boxes. $293.50 before shipping and taxes, or about $69 if you buy in the actual part count.
1pack95475A572
Zinc-Plated Steel Fully Threaded Stud, 1/4"-20 Thread, 8" Length, packs of 10
Monday morning$13.04 pack13.04
2
pack
95475A576
Zinc-Plated Steel Fully Threaded Stud, 1/4"-20 Thread, 10" Length, packs of 5
Monday morning8.26 pack8.26
3
pack
98055A099
Metric Spring Steel Shim - DIN 988, 1.0mm Thick, 5mm ID, 10mm OD, packs of 50
Monday morning8.62 pack8.62
4
each
6061K31
Hardened Precision Steel Shaft, 1/4" Diameter, 12" Length
Monday morning5.21 each5.21
5
each
6061K415
Hardened Precision Steel Shaft, 1/4" Diameter, 14" Length
Monday morning6.16 each6.16
6
pack
9600K22
Push-in Grommet, 1/2" ID, 1" OD, 3/32" Thick for a 3/4" Diameter Panel Hole, packs of 50
Monday morning9.54 pack9.54
7
4 each
62805K31
High-Cap Leveling Mount with Zinc-Plated Steel Stud, 10-24 x 1-1/2" Thread Length, 1-3/16" Base Diameter
Monday morning1.98 each7.92
8
each
1764K42
Steel Angle Ring with 6 Holes, 4" Duct Diameter, 9/32" Hole
Monday morning4.31 each4.31
9
pack
91420A320
Metric Flat Head Phillips Machine Screw, Zinc-Plated Steel, M5 Size, 10mm Length, .8mm Pitch, packs of 100
Monday morning4.05 pack4.05
10
pack
96659A101
18-8 Stainless Steel Type A SAE Flat Washer, Number 4 Screw Size, 5/16" OD, .02"-.04" Thick, packs of 100
Monday morning
2.96 pack2.96
11pack97416A115
Black-Oxide Steel Type A SAE Flat Washer, Number 10 Screw Size, 1/2" OD, .03"-.07" Thick, packs of 100
Monday morning3.82 pack3.82
12
pack
90631A003
Zinc-Plated Grade 2 Steel Nylon-Insert Hex Locknut, 2-56 Thread Size, 1/4" Width, 9/64" Height, packs of 100
Monday morning3.45 pack3.45
13
pack
90631A005
Zinc-Plated Grade 2 Steel Nylon-Insert Hex Locknut, 4-40 Thread Size, 1/4" Width, 9/64" Height, packs of 100
Monday morning2.55 pack2.55
14
pack
90257A411
Type 316 Stainless Steel Machine Screw Hex Nut, 10-32 Thread Size, 3/8" Width, 1/8" Height, packs of 100
Monday morning9.00 pack9.00
15
pack
94945A205
Grade 8 Steel Nylon-Insert Thin Hex Locknut, Zinc-Yellow Plated, 1/4"-20 Thread Size, 7/16" Wide, 13/64" High, packs of 100
Monday morning6.70 pack6.70
16
pack
90576A104
Metric Zinc-Plated Steel Nylon-Insert Locknut, Class 8, M5 Size, .8mm Pitch, 8mm Width, 5mm Height, packs of 100
Monday morning4.18 pack4.18
17
pack
91772A082
18-8 Stainless Steel Pan Head Phillips Machine Screw, 2-56 Thread, 5/8" Length, packs of 100
Monday morning4.15 pack4.15
18
pack
90402A146
Zinc-Plated Steel Pan Head Phillips Machine Screw, External Washer, 6-32 Thread, 3/8" Length, packs of 100
Monday morning6.95 pack6.95
19
pack
92000A118
18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M3 Size, 8mm Length, .5mm Pitch, packs of 100
Monday morning4.66 pack4.66
20
pack
92000A120
18-8 Stainless Steel Metric Pan Head Phillips Machine Screw, M3 Size, 10mm Length, .5mm Pitch, packs of 100
Monday morning4.34 pack4.34
21
pack
97334A992
Nylon Socket Head Cap Screw, 10-32 Thread, 1" Length, Black, packs of 100
Monday morning6.41 pack6.41
22
pack
91290A130
Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M3 Thread, 30mm Length, 0.50mm Pitch, packs of 100
Monday morning14.41 pack14.41
23
2 packs
91290A224
Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 10mm Length, 0.80mm Pitch, packs of 100
Monday morning9.41 pack18.82
24
pack
91290A228
Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 12mm Length, 0.80mm Pitch, packs of 100
Monday morning10.81 pack10.81
25
pack
91290A230
Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 14mm Length, 0.80mm Pitch, packs of 100
Monday morning11.52 pack11.52
26
pack
91290A252
Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 25mm Length, 0.80mm Pitch, packs of 50
Monday morning7.24 pack7.24
27
pack
91290A254
Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 30mm Length, 0.80mm Pitch, packs of 50
Monday morning7.87 pack7.87
28
pack
91290A256
Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 35mm Length, 0.80mm Pitch, packs of 50
Monday morning9.67 pack9.67
29
pack
91290A260
Black Class 12.9 Socket Head Cap Screw, Alloy Steel, M5 Thread, 45mm Length, 0.80mm Pitch, packs of 50
Monday morning11.24 pack11.24
30
pack
92146A005
18-8 Stainless Steel Split Lock Washer, Number 4 Screw Size, .21" OD, .02" min Thick, packs of 1000
Monday morning5.22 pack5.22
31
pack
92146A011
18-8 Stainless Steel Split Lock Washer, Number 10 Screw Size, .34" OD, .04" min Thick, packs of 1000
Monday morning11.14 pack11.14
32
pack
94785A411
18-8 Stainless Steel Square Nut, 10-32 Thread Size, 3/8" Width, 1/8" Height, packs of 100
Monday morning8.73 pack8.73
33
pack
94639A208
Nylon Unthreaded Spacer, 1/4" OD, 7/8" Length, #4 Screw Size, packs of 100
Monday morning9.35 pack9.35
34
pack
94639A350
Nylon Unthreaded Spacer, 5/16" OD, 1/8" Length, #10 Screw Size, packs of 100
Monday morning7.04 pack7.04
35
pack
94639A352
Nylon Unthreaded Spacer, 5/16" OD, 1/4" Length, #10 Screw Size, packs of 100
Monday morning7.45 pack7.45
36
pack
94639A454
Nylon Unthreaded Spacer, 3/8" OD, 3/8" Length, #10 Screw Size, packs of 100
Monday morning8.05 pack8.05
37
pack
94639A450
Nylon Unthreaded Spacer, 3/8" OD, 7/8" Length, #10 Screw Size, packs of 100
Monday morning9.64 pack9.64
38
pack
91770A096
18-8 Stainless Steel Truss Head Phillips Machine Screw, 4-40 Thread, 1/2" Length, packs of 100
Monday morning4.70 pack4.70
39
pack
91770A144
18-8 Stainless Steel Truss Head Phillips Machine Screw, 6-32 Thread, 1/4" Length, packs of 100
Monday morning4.35 pack
