frame mostly assembled
A project log for BuildLog Laser 2.x build
This week* i will be mostly putting together a buildlog.net 2.x laser
charliexcharliex 02/21/2015 at 21:320 Comments
lightobject saturday shipped my drivers , once i realised the smoothieboard was not even gonna come close (without external drivers, and then i feel its a waste of a board). lightobect have been great to me so far.
rear section (doge and frame)
  1. i pulled off the front pulley so i could take the trucks off and put them together upside down, much easier
  2. left side (no hackaday io i don't want list numbers)
    same with left side.
    mounted with the laser head, don't forget to put this on before the trucks
    mounted , oh for flips sake HTML editor bugger off with your numbers.......
  3. < O_o
    motor mounted
drivers
Si 25mm mirrors
in a box.
ok belts to install, some alignment and wire up the motors.
