PCB
A project log for R'lieh - Aquarium/ closed ecosystem management
An automated and connected aquarium management system
audrey-robinelAudrey Robinel 11/01/2016 at 13:370 Comments
Rlieh now has a real PCB instead of protoboards :)
It holds all the required components and breaks a lot of GPIOs :
This board also has extensions connectors for unused connectors, as well as jumpers to enable or disable power trough the arduino regulator, or disable the auto reset on serial.
The PCB is about 5*7cm, with M3 holes in each corners. This is the same footprint and fix holes as the 5*7 perfboard, so that it can be used as a drop-in replacement for the protoboards, and use the same cases :)
On the following picture you can see the back of the board (middle one) :
I'm pretty satisfied with it, and it was greatly manufactured!
In the next post, we will show an assembled board and describe it a bit.
