80C85 board
80C85 board designed by Sergey Kiselev, constructed by me.
80C85 processor 32K EEPROM 32K RAM GAL16V8 Runs Tiny BASIC and 8085 monitor.
I bagged nine OKI 80C85AH chips for just £8 on eBay. Rated 5 MHz clock according to the datasheet.
This project starts from a design by Sergey Kiselev. I intended to replace the 1-channel serial chip with a 16C552 which has 2 serial ports, internal baud-rate generation, and a parallel port, but that is not needed at the moment.
Basic Interpreter-8085-source.txt
Z80 CP/M Tiny BASIC Source code. Assembles but untested. See book by Rolf-Dieter Klein.
plain - 17.12 kB - 11/06/2021 at 01:30
Download
Basic Interpreter-8085-listing.txt
Z80 CP/M Tiny BASIC listing. Assembled but untested.
plain - 104.19 kB - 11/06/2021 at 01:30
Download
Basic Interpreter-8085-intel-hex.txt
Z80 CP/M Tiny BASIC Source code. Assembled but untested.
plain - 7.27 kB - 11/06/2021 at 01:29
Download
mon85-tinybasic-2.0-mini85.bin
Monitor and BASIC binary ROM image.
octet-stream - 8.00 kB - 05/15/2021 at 14:07
Download
tinybasic-2.0-mini85.zip
Tiny BASIC for 8085
Zip Archive - 33.17 kB - 05/15/2021 at 14:04
Download
View all 9 files
  • 1 × 80C85 Microprocessor, CMOS, 8-bit
  • 1 × RAM Power Management ICs / Power Supply Modules
  • 1 × ROM Power Management ICs / Power Supply Modules
  • 1 × 74ACT573 Electronic Components / Misc. Electronic Components
  • Project log
    Keith • 04/13/2020 at 16:48 • 0 comments
    I bagged nine OKI 80C85AH chips for just £8 on eBay. Rated 5 MHz clock on data sheet.
    Original intent was to base architecture on the Tandy Model 100, early laptop which ran for 20 hours on four AA cells.
    Four NiMH cells = 600 to 2850 mAh at 50mA drain, x 1.2 volts = 0.72 to 3.42 Watt-hours.
    This laptop claims 10.5 hours from a 32.5 WH battery
    http://store.hp.com/UKStore/Merch/Product.aspx?id=Z5F90EA&opt=ABU&sel=NTB
    So a model 100 should run 9.5 to 45 times longer!
    The Model 100 uses an 81C55 for parallel I/O and a 6402 UART for serial I/O. I had six of the latter, but none of the former.
    The Model 200 uses an 82C51A for serial I/O. This is not the chip used in the IBM PC (i.e. the 8250).
    https://en.wikipedia.org/wiki/Intel_8251
    https://en.wikipedia.org/wiki/Intel_8250
    The 81C55 used the timer for baud rate control. If I use a UART with internal baud rate generation (the 8250) then I only need parallel I/O for the keyboard. A 74HCT574 and 74HCT245 should do. Later UARTs had 16-byte buffers (16C550) and printer ports (16C552).
    http://www.ti.com/lit/ds/symlink/pc16552d.pdf
    The tape interface can be safely abandoned. Solid state storage is widely available.
    Farnell sell the 4-channel, no LPT version in LQFP (0.5mm pitch):
    http://uk.farnell.com/texas-instruments/tl16c554aipn/async-comm-element-1mbps-lqfp/dp/2335690
    and the 2-channel 1-LPT version in PLCC68 for £7.30:
    http://uk.farnell.com/texas-instruments/tl16c552afn/async-comm-element-1mbps-plcc/dp/2335689
    Bought an MSM81C55 chip. I may not use it, but it will be there if I want to experiment.
    2019-11-10
    Bought a ready-made PCB: http://www.malinov.com/Home/sergeys-projects/minimax8085
    This will avoid a lot of wiring work. Since it is a ready-made computer already, I need to improve it.
    The 8251 is primitive and there is no user I/O for this board. So I shall use an 16C552 chip, which has two serial ports and a parallel I/O port.
    2020-04-25
    Fitted:
    U1 80C85 CPU socket
    U3 ROM socket
    U4 32K RAM socket
    U5 GAL16V8 socket
    U6 74HCT573
    2020-04-25
    Fitted:
    Fit links for 32K EEPROM
    Fit 5V inlet
    2020-06-06 weekend
    Program GAL
    Program EEPROM
    Fit 10MHz crystal (near enough ideal 9.8304 MHz to work)
    Order null-modem adaptor for neater solution in future
    Create null-modem adaptor to get going this weekend
    Check board works with 8251 serial port and unmodified software
    Success, it runs Tiny BASIC, at 19200 baud. I will replace that with the dual monitor-BASIC ROM.
    To do:
    Replace 10 MHz crystal with 9.8304 MHz.
    Modify hardware and firmware to use 16C552 chip
    Build 16C552 board with serial and parallel ports.
View project log
