Full Sonar v1 opt corrected external clock.schEagle Schematic for a dedicated board containing the complete system.sch - 447.78 kB - 08/19/2018 at 12:19 |
Full Sonar v1 opt BOM.txtBOM for the dedicated board with the complete system.plain - 8.55 kB - 08/19/2018 at 12:19 |
Full Sonar v1 opt corrected external clock.brdEagle BRD file for a dedicated board containing the complete system.brd - 208.26 kB - 08/19/2018 at 12:18 |
Interconnection Diagram.pngDiagram showing how to connect the prototype boardsPortable Network Graphics (PNG) - 781.04 kB - 01/28/2018 at 19:57 |
power proto routed.schEagle schematic for the output stagesch - 337.04 kB - 01/07/2018 at 22:33 |
power proto routed.brdEagle board file for the output stagebrd - 102.42 kB - 01/07/2018 at 22:33 |
microphone proto routed.schEagle schematic for the MEMS microphone board.sch - 56.33 kB - 01/07/2018 at 22:33 |
microphone proto routed.brdEagle board file for the MEMS microphone board.brd - 40.15 kB - 01/07/2018 at 22:33 |
sonar.zipKinetis Design Studio project for FRDM-K64 development board.x-zip-compressed - 4.17 MB - 01/07/2018 at 22:52 |
srl_read_array_int16.mOctave function which does a serial binary read of a 16 bit integer array.m - 1.22 kB - 01/27/2018 at 16:44 |
ultrasonic2.mOctave file that is used to display target data and auto-correlation. Uses serial IO with the OpenSDA connection to the FRDM K64F board.m - 3.32 kB - 01/07/2018 at 22:44 |
