Top.stlTop part off the case. Has clips to hold the board - they don't work - cut them off, and drill two 2.5mm holes in the rear two stalks, and screw the OrangePi in.Standard Tesselated Geometry - 878.01 kB - 01/07/2018 at 10:14 |
Base.stlBase section of case. Attaches to the Top with 4 x M3 screwsStandard Tesselated Geometry - 176.64 kB - 01/07/2018 at 10:14 |
